voltage and temperature acquisition at the same time
I have some problems with acquiring temperature and voltage with PCI 6281. I want to acquire voltage to detect AC crosing zero. When voltage is zero, I want to detect temperature.If I put volatge and temperature reading in one task, I can read them.  However, if I put voltage and temperature  in two different reading task, only voltage can be obtained. Temperature reading is always zero. I am not sure if there is a way that I read temperature and voltage separately.
(4,000 Views)
What was wrong with the responses you got in your other thread?
(3,995 Views)
