web service setup
I have a cFP-2200 real time controller running LabView real time 4.5.5 and I am programing in LabVIEW 8.6. I setup a real time project with continous communication, multiple loops, fileI/O, and host user interface configuration of Remote Panel. I am having trouble setting up the web services.  I have configured the web server using the Real Time  Fieldpoint Properties.  See Below. figure 1and I set the visible VI to my main Vi target - mult rate - fileIO.vI. I left the browser access set to * which I assume means all.  After I set the configuration I deployed it to the controller.
Is there any other steps to configure the cFP2200 for using a remote front panel in a browser?
Do I need to configure the VI server also?
 Figure 1
(3,505 Views)
Hi Rocke72,
I am a little confused with your setup. You said you have LabVIEW RT version 4.5.5, however you have LabVIEW 8.6. These two versions should not be compatible. Are you sure about these versions?
FLash
(3,492 Views)
Below  you will see the configuration of software I now have on the cFP2200. I am down grading the project to 8.5.1 and trying it. I read in another thread about issues with 8.6 which where to be fixed in 8.6.1 which I don't have access to.
I hope this combination works?
(3,476 Views)
