when i run rt plus fpga i am getting this error
(Hex 0x627) The function name for the LabVIEW:FpgaViInTimedLoop:C node cannot be found in the library. To correct this error, right-click the Call Library Function Node and select Configure from the shortcut menu. Then choose the correct function name.
Message 1 of 1
(5,370 Views)
