wireless image acquisition ,range 500 m?
i am doing my final year project ,its wireless image acquition , range 500m (min).is it feasible and if yes then the solution for it.
(3,279 Views)
To whom it may concern:
Wireless image acquisition is something that we don't natively do through our image acquisition boards here at NI. We have framegrabber boards which you cable straight to your camera, analog or digital. We also have a driver that will work with IEEE-1394 boards (Firewire). Where you're doing this wireless image acquisition, you'd need to have a camera and an interface at the computer that are capable of communicating. That interface at the PC will probably have some drivers that handle things on the software side. You can call those drivers from LabVIEW and import those images you're receiving for further analysis/manipulation with our Vision tools if you like. In fact, those drivers might even have VIs already made up for LabVIE
W. You'd have to verify that with the manufacturer of the wireless interface at the PC.
Hopefully this is helpful to you in getting things going. Best of luck...
Jim Laudie
Applications Engineer, National Instruments
(3,279 Views)
