SAPHIR - Toolkits Discussions
Error 6101 occurred at ModBusVIEW TCP
Dear all. I install the Modbus view and when i use:
Then I configure the ip and port of one device(power meter with serial communication and thet tcp router so the protocol is modbus over tcp)
the Id number is 1 and i want to read holding register but here is the error msg.
Could you give me some advice to fix it:
(4,861 Views)
Hello Bochev,
Thanks for using our addon,
If you take a look on the documentation of the toolkit, the 6101 error correspond to a timeout error.
A timeout error often occur when you can't communicate with your device. Are you able to ping your device ?Could you tell me which device your are trying to connect ?
(4,354 Views)
