SAPHIR - Toolkits Discussions
Error installing ViBox - Probes v1.3.0.21 on LabView 2013
When attempting to install ViBox - Probes v1.3.0.21 on 32 bit LabView 2013 with a Win7 64 bit machine through the VIPM utility, I receive the following error:
Main Package Name: ViBox - Probes v1.3.0.21
Package Name with Error: ViBox - Probes v1.3.0.21
Error Message: VIPM could not install the package saphir_lib_vibox_probes-1.3.0.21 .
Error Code: 8
Error Source: Open/Create/Replace File in ZLIB Read Compressed File__ogtk.vi->ZLIB Get File__ogtk.vi->ZLIB Extract File__ogtk.vi->CECD298A8C01713454E8229D444EA5B9->AD5C8264C085DE21572840347977323F->OGPM Class.lvlib:DA634C8935AD308A336B32981281203B->OGPM Class.lvlib:ECA9B1EEBFC60204894E445D02301EEE->AAD7C4B4FB57FDE8AE33932F9B4A3584->VIPM Main Window.vi<APPEND>
C:\ProgramData\JKI\VIPM\cache\saphir_lib_vibox_probes-1.3.0.21.spec
Any ideas on the source of this problem?
(7,902 Views)
It looks like a permissions problem. Run VIPM with admin priviladges and try again.
(6,298 Views)
Hello dvase,
Did Michael's solution fixed your issue ?
Olivier
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
(6,298 Views)
Running VIPM as admin did the trick, thanks for the help.
(6,298 Views)
Glad to hear that and thank you Michael for your help.
Olivier Jourdan
(6,298 Views)
