SAPHIR - Toolkits Discussions
SAPHIR - GDataBase for MySQL No Longer Using Softwarekey?
I am the owner of a copy of the GDataBase for MySQL toolkit.
I went to active it on a new computer I bought for this year and it says that Saphir no longer has a SoftwareKey account.
If this is the case how can I active my software?
Ken
(4,998 Views)
HI,
Our toolkit are not sold anymore on LVTN since 01 nov 2022...
However we still support licences bought before this date.
We should push our toolkits on open source repo one day
Until then, You can download a copy of the source code at this link (available 7 days), and replace it in your source code : https://file.qmt-group.com/index.php/s/cLL3Q4sGAzE48GJ
Christophe | Armatan | Certified LabVIEW Architect
(4,972 Views)
is it compatible / tested / used on Linux Desktop?
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(4,969 Views)
Thank you! Can you please change the software distributed via the VIPM to be without a license? That would be most helpful.
(4,960 Views)
I also purchased and used your toolkit a few years ago, but now am switching to a different computer.  Would you mind re-sharing this source code, or change to toolkit in the VI Package Manager to be without a license?
Thank you,
Brandon
(4,626 Views)
The source code is available on gitlab : https://gitlab.com/QMT-group
Beware, the build vip file is not working properly currently : either use directly the source code, either correct and rebuild the vipb (We should fix it within a few days or weeks...)
(4,613 Views)
