SAPHIR - Toolkits Documents
SmartSQLVIEW for MySQL datasheet
  • SmartSQLVIEW for MySQL toolkit is an add-on to NI LabVIEW that add capabilities to connect MySQL databases from any LabVIEW program.
  • SmartSQLVIEW for MySQL is compatible with the LabVIEW Real-Time Module.
  • With SmartSQLVIEW for MySQL you can easily connect your test and measurement applications to "the world's most popular open source database".
  • SmartSQLVIEW for MySQL is really easy to install. It does not require additional component to be installed but the toolkit itself.
Features
SmartSQLVIEW for MySQL toolkit supports the following features :
  • Open connection to database
  • Execute SQL queries
  • Manage queries with transaction
  • Test database communication tool allowing quick communication checking
  • Simple request and performance examples
LabVIEW components
Functions palette
SmartSQLVIEW for MySQL toolkit is located in SAPHIR palette
NameIconHelp
Open databaseMySQLVIEW-open.pngThis VI attempts to establish a connection to a MySQL database engine running on host. This VI must complete successfully before you can execute any other API VI.
Execute SQL query
MySQLVIEW-query.pngThis VI executes an SQL query.
Close databaseMySQLVIEW-close.pngThis VI closes a connection to a MySQL database engine previously opened.
Create transactionMySQLVIEW-BeginTransaction.pngThis VI creates a new transaction. Such transactions usually persist until the next COMMIT or ROLLBACK command. But a transaction wills also ROLLBACK if the database is closed or if an error occurs.
Commit transactionMySQLVIEW-CommitTransaction.pngThis VI commits all modifications that occurred on the database since the last call of the method BeginTransaction.
Rollback transactionMySQLVIEW-RollbackTransaction.pngThis VI cancels all modifications that occurred on the database since the last call of the method BeginTransaction.
Get table informationMySQLVIEW-TableInfo.pngThis VI provides information about each non-temporary tables.
Get columns informationMySQLVIEW-ColumnInfo.pngThis VI provides information about each column of a given table.
Ping server
This VI tests the connection and reset the connection inactivity counter in the MySQL server.
Get server statisticsMySQLVIEW-Statistics.pngThis VI returns some MySQL server statistics.
Examples
SmartSQLVIEW for MySQL toolkit is provided with comprehensive examples demonstrating how to access MySQL database. You can find them browsing "NI Example Finder".
  • Simple request : This example demonstrate how you can open/create, insert and retrieve data from MySQL database.
  • Insert benchmark : This example allow you to make INSERT performance test into MySQL database.
Tools
SmartSQLVIEW for MySQL is provided with a useful tool allowing to quickly test communication with any MySQL databases. You can find it in Tools >> SAPHIR >> SmartSQLVIEW for MySQL >> MySQL database connection test...
Requirement
  • LabVIEW version : 2010 or later
  • Operating System : Windows*
  • Compatible with the LabVIEW Real-Time Module
  • VI Package Manager from JKI - Community Edition For installation process
  • At least one MySQL database server version 5.x (Note that SmartSQLVIEW for MySQL does not provide any componant of MySQL)
Download and purchase
* Please contact us if you are interested in support for other Operating Systems like Linux or Mac OSX
Olivier Jourdan
Wovalab founder | DQMH Consortium board member | LinkedIn
Stop writing your LabVIEW code documentation, use Antidoc!
Contributors
