San Diego LabVIEW Users
Sorensen DHP Power Supply Current, Voltage, and Power Readings
Hello all, this is my first blog post, so if you can suggest any details on blog ettiquette and posting please do!
Going to my question, it seems that the Sorensen DHP power supply accepts and executes commands from a modified VI, which was modified from the original version found here: http://www.sorensen.com/products/DHP/DHP_Downloads.htm
However, there is a file read feature on the VI which should display a numeric string displaying the current, voltage, or power level (depending on user choice) as it's sent from the power supply, which does not display. This would normally be used to ensure that the power supply is executing the user-specified amperage.
How can I get the power supply readings to display?
(11,545 Views)
Hey lbv_dude,
The LLB includes a bunch of VIs for that power supply.  I would make sure you are running the correct VI and also confirm that you are able to get at least a response back from something basic like a *IDN?
I'm the local representative for NI in San Diego.  Please feel free to call me at 619-208-8120 to share more about your project and I'll see if either myself or my colleagues in Austin can help.
Best Regards,
Song Mu
National Instruments San Diego
(4,207 Views)
