Serbia LabVIEW User Group
Čestitke na inicijaciji
Hvala Miloše na organizaciji vrlo uspešnog prvog meetup-a!
Hvala i prezenterima na uloženom trudi i vremenu, bili ste odlični!
A hvala i svima koji ste došli na dobrom druženju.
Jedini propust nam je bio što nismo napravili zajedničku fotografiju, ali eto lake prilike da sledeći put budemo još bolji 🙂
(94 Views)
Thank you to everyone for your hospitality at this group meeting. I really enjoyed meeting everyone and learning about your LabVIEW usage. Please reach out to me directly if I can support you in future or you need a contact at NI.
As promised here is that list of quick drop shortcuts - and yes I checked... you can also ask Nigel about this 🙂
Super Quick Drop – click to drop!
Quick Drop Object Shortcuts (‘cs’, ‘rn’, 'nv', ‘ad1’, etc.)
Ctrl-Key Shortcuts - press Ctrl-Space, then...
  • Ctrl-B – Set property/invoke node class
  • Ctrl-Shift-B – Set property/invoke node property/method
Including dotted properties
  • Ctrl-W – wire multiple objects together
Ctrl-Shift-W will also clean up the wired code
  • Ctrl-I – insert an object on one or more wires
Ctrl-Shift-I – smart insert a single object on multiple wires
  • Ctrl-R – remove selected object(s) and rewire pass-through types
  • Ctrl-P – replace one or more selected objects
  • Ctrl-D – create controls/indicators (type ‘req’ for creation of required inputs only)
  • Ctrl-K – Assign text-based icon to VI
Graham Green
Software Product Marketing
NI | Emerson
(73 Views)
