Sheffield LabVIEW User Group
LabVIEW Tip: Delete a SubVI/node without reconnecting the wires
Select the SubVI/Node you want to delete, then press Ctrl – space (yes, the way to activate Quick Drop) and then press Ctrl – R. The SubVI/Node will be deleted and the wire is reconnected.
LabVIEW Tip - Delete SubVI or node without reconnecting the wires screenshot
Want to receive our LabVIEW Tips via email each month? Subscribe to our newsletter and we’ll add you to our monthly mailing list. We will not pass your details on to any third party organisations.
You can also join the conversation on Facebook, Twitter and Google+!
The post LabVIEW Tip: Delete a SubVI/node without reconnecting the wires appeared first on Austin Consultants.
(7,521 Views)
Since LabVIEW 2015 you can simply right click the node you want to remove and select "Remove and Rewire" option from the pop up menu and get the same effect.
(6,266 Views)
