Sheffield LabVIEW User Group
Multiclass classification in LabVIEW using SVM and one-vs-all method
Dr Bo Fu is a Certified LabVIEW Developer and joined the Austin Consultants team in December 2013 as a Systems Engineer. Dr Fu joins us from the University of Nottingham where he completed his PhD and did a Postdoc in Electronic Engineering, developing a high-speed dynamic-sampling camera and a real-time control spatial light modulator.
Dr Fu is currently working on a very exciting project involving a combination of different AI techniques including Neural Networks, K-means and SVN to name a few. Dr Fu posts regularly on his  blog and has written the post below about using SVM to do multi-class classification.
Dr Fu explains:
“Today I came across a problem to use  SVM to do multi-class classification. The  toolkit downloaded from NI did not provide the ability to do multi-class classification with SVM but only for two classes (it’s quite a useful tool still). So I took use of the SVM VIs and made a multi-class version using one-vs-all method.
There is a good  tutorial on one-vs-all or one-vs-rest classification by Andrew Ng. We pick one class each iteration as Class A and make the rest classes as Class B. Only the test data that locate in Class A are allocated to the known class. Here is the code:
LabVIEW_Machine_Learning
The original trained labelled data are classified as Class 0, 1, 2, … N. In the i-th iteration, only the data from Class i are re-classified to Class 1 and the rest data are re-classified to Class 0. When the test data locate in class 1 area, they are classified as Class i. Any unsorted data are left in Class -1.
When I test the performance of this one-vs-all classifier, the result seems fine.
Message 1 of 1
(5,732 Views)
