Signal Conditioning
0-5v to 4-20ma
I have a transducer which outputs 0-5V signal , but I want that signal to convert it to a 4-20 ma signal. Is there any NI equipment capable to do that?
thank you.
(2,554 Views)
I do not know of any NI signal conditioning to handle this.  A quick Google search led me to this: https://www.sensorsone.com/0-5v-to-4-20ma-signal-conversion/
You can probably do some search at a robotics and/or hobby site to find something smaller.
GCentral
(2,531 Views)
I used some ADAM 3014 modules (isolating, configureable ) in the past for industrial like use.
Greetings from Germany
Henrik
LV since v3.1
(2,499 Views)
If you're capturing using a DAQ system, you can directly capture it as a 0-5V signal instead of converting it into a 4-20mA signal and then capturing it.
Additional information about the application will help to understand the reason behind conversion from 0-5V to 4-20mA signal.
Santhosh
Soliton Technologies
(2,428 Views)
