Signal Conditioning
1102/1303 CJC temp diplay w NI DAQ assist LV7?
I am trying to display (Graph)the CJC temp using Ni Daq assist. I do not see the CJC as a selectable output. Can this be done? Using a 1011 chassis with the SCXI-1102 and 1303 terminal block (internal CJC thermister).
(2,998 Views)
Greetings,
This is definitely possible with NI-DAQmx, but not with the DAQ Assistant. The example Acq CJC Temperature.vi demonstrates how this is accomplished. This example is available in the following location:
Hardware Input and Output >> DAQmx >> Analog Measurements >> Temperature
The example only acquires a single reading, but you could easily modify it to continuously acquire and chart the CJC temperature.
Good luck with your application.
Spencer S.
(2,998 Views)
