Signal Conditioning
3-wire RTD connection to SCXI-1306
I have read the NI Manual for 3-wire RTD connection with SCXI-1306 but I couldn't understand completely.
Where to connect each cable is understood: one RED cable in AI-; Black to AI+; and Black-2 to IEX+. Like Fig. 4 from SCXI-1306 Terminal Block Manual.
My question is regarding the switches: the manual shows only 2 swiches (Fig 4) and the first is down and secound up. Looking at the Terminal Block there are 4 switches and not only 2.
How should I place the switches?
(7,055 Views)
From the specification of SCXI-1306, Figure 2, there is only 2 switch per channels.
Can you help to attach the picture showing your SCXI-1306?
Thanks.
KwokHow
Applications Engineer | National Instruments
Singapore (65) 6226 5886 | Malaysia (60) 3 7948 2000 | Thailand (66) 2 298 4800
Philippines (63) 2 659 1722 | Vietnam (84) 28 3911 3150 | Indonesia (62) 21 2783 2355
(7,022 Views)
Thanks for your help. It was my misunderstanding!
(7,013 Views)
can you please tell me what is used for the "SW1" switch in the left-upper corner of the picture that you attached? Seems that I can't find anything about that in the web.
Best regards
Andrea
(2,770 Views)
