Signal Conditioning
3 wires rtd configuration
i'm not able to configure the 3 wires RTD software configuration. i'm using SC2345 and SCC-RTD01. i'm not able to find a specific 3 wires connectionc onfiguration when installing a new channel into the nidaq-virtual channel menù. The default config fits only the 2 and 4 wires connection. How can I subtract the value of the x+8 channel to the x? Can I manage the subtraction directly from the Measure and automation software?
Thanks all
(3,352 Views)
I suggest you follow the step-by-step instructions detailed in the following Tutorial and LabVIEW Example Program:
- SCC Tutorial Series: SCC-RTD01
- SCC Example Series: SCC-RTD01
AlessioD
(3,352 Views)
