Signal Conditioning
50 pin of SCXI-1349
Hi everyone
I have problem with SCXI-1349 ,,, I connect it to SCXI-1180 feedthrough and I use SCXI-1302 terminal block , I don’t know the connection on that terminal block ,, there are 50 screw in the board but I don’t know what is that mean
Is that mean 1,2 for ch1 for example or what??????
Also when I chick in the MAX I don’t saw the SXI-1180 on chasses ,,, could anyone help me ????????
(5,991 Views)
The SCXI-1180 is a breakout cable that allows you to gain access to the unused pins of your DAQ card that have been connected to the SCXI chassis.  The pinout of the SCXI 1302 terminal block is the same at the 50-pin connector of the SCXI-1349.  See the following links:
SCXI-1302 with M-Series DAQ card
https://www.ni.com/en/support/documentation/supplemental/18/scxi-1346-and-scxi-1349-breakout-pin-tra...
SCXI-1302 with E-Series DAQ card
http://digital.ni.com/public.nsf/allkb/4C80B2FAAE20D76886256A3F007F0D8C?OpenDocument
Chris_K
Message Edited by Chris_K_ on 02-21-2008 04:37 PM
(5,980 Views)
