Signal Conditioning
5V trigger every other second
How can I send a +5v trigger pulse for one second, then break for one second, then send another +5v trigger, etc?
My biggest problem is having the 1 second pause between pulses. The pause is to allow a peripheral nerve enough time to recover from stimulation. I apologize if this is a very basic question, I am quite new to this programming environment, or any programming environment for that matter.
Thanks for your help.
-OG
(5,661 Views)
What kind of hardware do you use to send out the trigger?
And what timing requirements do you have?
Attached is a simple software timed version. Lot's of room for improvements, see timed loop or timed sequence . If you have the IO hardware you can do very precise hardware timing.
Greetings from Germany
Henrik
LV since v3.1
(5,647 Views)
