Signal Conditioning
Dear all:
    I use PXI-6070 to measure two different type of signals (DIFF mode and RSE mode),ch0 and ch8 are uesed to mesure DIFF voltage (about 4.5V ,ch0 to AGND is about 25V,ch8 to AGND is about 20.5V).
   Ch1 and Ch2 are uesed to measure RSE voltage(1.8V and 3.3V).
  Question:
  (1) Can the channels be configed to different type when measure different voltages in the same routine?
  (2) If one channel is out of the range(10V),will it effect the other channels?
  Best Regards
  James
(6,171 Views)
you can configure DAQ channels separately.
(6,157 Views)
