Signal Conditioning
AUX cable expansion
I have a SCXI 1001, with SCXI 1129 module. It is connnected to a PC that has a DMM 4060.
The problem  is that I have a 2 m AUX cable but the project design  design is such that it needs 3m length.  It will take at least 10 days to ship matrix expansion cable. So can I get more information about the cable so that I can make a temporarily cable by myself?
Its an urgent issue.
Rohit Dasrapuria
Message Edited by Support on 08-05-2005 04:05 PM
(3,299 Views)
Ho Rohit,
What is the part number of the cable you are using? What 2 units does this cable connect between?
If I know which cable you're referring to, then I can send you detailed information on this cable, and you will be able to build an expansion to it yourself.
Best Regards,
Evan R.
http://www.ni.com/support
(3,278 Views)
