Signal Conditioning
Acquirement in double buffered mode with a SCXI-1102 and the cold-junction temperature (CVI)
I need to acquire some temperatures with SCXI-1102, but under CVI, in the double buffered mode, the result seems to be a variation with the cold-junction temperature.
How can I include the measure of the cold-junction temperature without take a single point of this one at the start of acquirement.
(If I want to use the "SCXI_Scale" and "Thermocouple_Buf_Convert" function)
(5,369 Views)
Hello;
I'm attaching an CVI example showing how to do termocouple readings with the SCXI-1102 module. Use that example to double check if the same problem shows.
Hope this helps.
Filipe
(5,369 Views)
NI France gives me the solution for a real double buffered mode.
N.B. : Thank you for your answer Filipe.
(5,369 Views)
