Signal Conditioning
ActiveX for SC-2350
My SC-2350 (with installed SCC-AI03, SCC-SG24) connects to PC via PCI-6221.  Where can I find the ActiveX control or library to get analog signal from 2 above modules?
Thank you.
David
(3,186 Views)
Hello David,
What are you using to call the DAQ board?  If you are using .NET or another text language you can use the documentation installed with the NI-DAQmx driver.  This documentation is created at: C:\Documents and Settings\All Users\Start Menu\Programs\National Instruments\NI-DAQ, the C Reference Help is useful.  It includes documentation about the NI-DAQmx API.
I'm not sure that quite answers your question, if not, post again.
Micaela N
(3,178 Views)
