Signal Conditioning
Arduino, LapView and real time filtering setup
Hi my Friends,
I have a simple setup of a loadcell + amplifer+ arduino + Labview through Linx, I am collecting data in real time at 1000 sample per second speed
But I am missing the filter part and i want to do a low pass filter through LabView but, the DAQ Assistant can't be used with arduino as I understood.
Is there is a way to filter the arduino signal through labview.
Thank you very much for your help in advance.
(2,846 Views)
There are digital filter VIs in LabVIEW.  Look in the Signal Processing->Filters palette.  You will need at least the Full Development license to use them.
I also advise you get away from using the Express VIs such as the DAQ Assistant.  They tend to hide too many details that are very important.
(2,837 Views)
