Signal Conditioning
Attenuation and noise adding SCXI-1125 and SCXI-1327
I am trying to measure 6 signals and results of all are incorrect.
My modules: PCI-6251, SCXI-1001, SCXI-1125, SCXI-1327.
Three of my signals are rectified 230VAC, and other three are digitals (different frequency, max 7kHz), with high level 3V3.
I have two kinds of problems:
1. Measured signals are different then real (also different then signals measured at the same time on oscilloscope)
2. Three digitals signals are deformed by the other signals, even when I disconnect this three shape of digitals signals is still incorrect
3. Measured values on oscilloscope are deformed and incorrect when I connect SCXI module with board (it does not matter is SCXI1001 is turn ON or OFF)
My settings:
hardware junctions: three digits: 1:1, three AC 100:1
software attenuation: three digits 1, three AC 100
Sampling frequency: three digits 16kHz, +/-5V, Three AC 1kHz, +/-300V
What is wrong with this measur devices or what I should change in my measure settings to get correct results?
(5,906 Views)
This looks like quite a complex topic for the forums.
I suggest you to contact the your National Instruments branch for troubleshooting your system and identify whether it is an architecture problem or faulty HW.
You can find a toll free number for your country by visiting:
www.ni.com/country  (country- name of country of origin)
Thank you
Emil
Please relpy if you managed to get in contact with your local representative
(5,889 Views)
