Signal Conditioning
Bad readback voltage from SCXI 1331 / 1127 /1000
I am using SCXI 1000 with 1127 with1331 in our application with the 2 wire configuration. My application is to read and log all the cell voltages(31 cells) and during the application i am not able to get the correct read back voltages for the cells between cell 17 to cell 31. When i did the root cause analysis i found grounding any polarity of any cells which results me to get the bad read back voltage from cell 17 to cell 31 and all the cells were around 2.3 V.
-Karthick
Message 1 of 1
(5,892 Views)
