Signal Conditioning
Bandpass Zero phase Filtering
I tried implementing zero phase filter for filtering noisy EEG signals.
It is behaving like a bandstop filter when tried bandpass mode.
but bandstop, HPF, LPF are working properly.
I tried cascading of ZPHPF & ZPLPF but it also didn't work.
What would be the problem with my VI?
(4,823 Views)
It appears that the typecast function in Zero Phase Filter.vi is sending the wrong information to Butterworth Coefficients.vi.  I placed U32 numeric indicators on the Type output of the Unbundle and on the output of the typecast.
Type Unbundle  Typecast out
Lowpass   0            0
Highpass  1            3
Bandpass 2            3
Bandstop  4            3
That may not be the only problem however. When I bypassed the typecast, I still get NaN outputs for both bandpass and bandstop filters.
Why are you sampling at 500 kHz and then resampling to a much slower rate?  When I apply the same filter specifications to the raw data, I get the results shown below.
This was using Digital IIR Filter.vi from the Waveform Conditioning palette (LV2015). I am not sure whether the filter VIs have changed since LV 2011.
Why are you worried about a zero phase filter? The spectrum of the raw signal appears to be essentially random.
Lynn
(4,804 Views)
Numeric filter don't like to have a 500kHz Samplerate and a filtersetting of 1Hz to 45Hz.
Think of a 1Hz sine sampled at 500kHz and a 4th order filter. the coefficients will scrap at the lower end of the numerical resolution ....  add noise and the filter is quickly lost 😄
Decimate (with filter) to 500Hz samplrate and try again 😉
Another way to compensate the filter phase of  finite samples is  to filter twice with reversed data.
data -> filter -> reverse data -> filter - reverse data
Greetings from Germany
Henrik
LV since v3.1
(4,794 Views)
Hi Lynn & Henrik,
I got a problem in calcualation of percentatge of similarity between two EEG signals which are acquired by diffent type of electrodes  by using correlation technique. I tried avearaging the data 500Khz at 1000 samples also.
I believe that i am not getting the correct value of percentage.
I am auto correlating the referance signal and maximum of autocorrelation was found out.
similarly  i am crosscorrelating the referance signal with test signal and finding out the maximum.
from those two vaues i am tryoing to find out percentage of similarity.., is it correct aproach??
Please lookinto the attached VI.
(4,689 Views)
