Signal Conditioning
Blood Pressure monitoring system using the LABVIEW
Also, you could avoid using multiple case structures for each boolean button
Message 11 of 20
(3,550 Views)
thanks for the feedback... hehe.. i have already tried .. the values can be save but not the systolic and diastolic values.. as i only need one value for each but it appear alot of values... but i thought i have already added the statistics for the mean... ?
Message 12 of 20
(3,547 Views)
i tried to prompt the user to enter the name and after that the user has taken its blood pressure... both the systolic, diastolic and name will be save in the excel.. but i fail to do it.. no idea why?
Message 13 of 20
(3,548 Views)
Sheena,
The example below uses the “Prompt User for Input” express VI to get the users name, and then concatenate this name with the data so that it will appear in your spreadsheet. Please feel free to alter this code, and concatenate strings how you would like. After the concatenation, it saves the data to a tab delimited file, which can be opened using Excel.
David L.
Systems Engineering
Message 14 of 20
(3,530 Views)
Hi.. i cant open the file because i using labview 8.. your version is the new version... sob  sob.. but thanks anyway
sheena
Message 15 of 20
(3,525 Views)
Here is the same example in LabVIEW 8.0. Thank you for letting me know the version of LabVIEW you have.
David L.
Systems Engineering
Message 16 of 20
(3,523 Views)
thank you so much david... i will try the codes later and try to understand the codes...
sheena
Message 17 of 20
(3,520 Views)
Can I know bout the hardware you are using for the BP project. It would be helpful if you can a post a pic of your hardware setup!
Message 18 of 20
(3,102 Views)
hi....
can u tell me how to aquire blood pressure??...which sensor u used for measuring blood pressure....!!
m waiting for reply .bcoz its urgent
thank you
u can contact me on my id bhavin_bme@yahoo.com
Message 19 of 20
(2,065 Views)
could you kindly have a look at the following link and give any idea about it pls
https://decibel.ni.com/content/blogs/noninvasivebloodpressure/2012/07/26/non-invasive-blood-pressure...
Message 20 of 20
(1,850 Views)
