Signal Conditioning
CA-1000 Specifications
I want to use a CA-1000 to enclose one or possibly two CB-68LPR boards and four 9-pin D-Sub connectors. I want to fit a custom circuit board in there as well (as a failsafe), so I'm looking for specifications of where the mounting standoffs are within the CA-1000. Is there a document you have that lists these specifications?
I could not find that information in the accessory install guide or the "data sheet & specs" document.
Steve
(4,987 Views)
Steve,
The two documents on our web site that may be most helpful to you are the dimensional drawing: http://digital.ni.com/hardref.nsf/f0741d25de0cf5fe8625665800529188/9c0f62cfe078b63986256c83004e90b5?OpenDocument, and the User Manual: http://digital.ni.com/manuals.nsf/webAdvsearch/E35C01A676A650DF862569BB005BE117?OpenDocument&vid=niwc&node=132100_US. Have a great day!
(4,987 Views)
Thanks -- this definitely helps.
Is there any information on what size screws I would need? The mounting standoffs are already installed, right?
(4,987 Views)
Hi Sarah,
I ran into this thread today (17years after it was posted wow) and I could not open the first link you provided. I can only find the user manual of CA-1000 but not the spec sheet. Could you tell me what the first document was about? Thank you!
-Hiriam
(3,344 Views)
