Signal Conditioning
Can I configure a voltage divider on a SCXI-1100 card in order to read a 24V DC signal without external circuitry?
I would like to know if I can configure a voltage divider without having to wire external circuitry. I know that there are pads for a filter capacitor and current to voltage resistor on the SCXI-1100. COuld these pads be used to solder in a precision resistor to serve as a voltage divider? The voltage I am trying to measure is a 24V DC signal."
(3,152 Views)
Hello;
The pads you can see on the 1100 are pretty much bread boards that you can use to build your own circuitry on.
You can build a voltage divisor on that space, just make sure to follow the current specs of the SCXI module.
Regards
Filipe A.
(3,152 Views)
