Signal Conditioning
Can I configure the vitual channals for all the signal conditioning modules?
One module is connected to the DAQ board. I know I can configure vitual channals for this module. Can I do the same to other modules?
(3,153 Views)
Yes. As long as Measurement and Automation Explorer (MAX) verifies the chassis and all of the installed modules, you will be able to create virtual channels for any of the modules - so long as the channel you select is appropriate for the action required. For example, you could not select an analog output channel for an analog input operation. The channel setup wizard is designed so that when you create a virtual channel, the device selection portion will allow you to select any appropriate module or channel that is recognized by MAX. If for some reason you can not select the channels, check the setup in MAX to verify the chassis. You may need to adjust the chassis/module settings to create a valid chassis.
(3,153 Views)
Hello;
You definitely can do that. You will just need to input the correct address on the channel string so your virtual channel will reffer to the correct module.
Regards
Filipe A.
(3,153 Views)
