Signal Conditioning
Can I hook up a TBX-1303 to a SCXI-1141?
Sorry if this is the wrong place to ask this question...
I want to use an SCXI-1141 to make some really small voltage measurements.  The only terminal block that I have is the TBX-1303.  Can I connect the two to do this?
m
(5,387 Views)
Hi mvilla,
This is a great board to post your question. Unfortunately, you cannot use the SCXI-1141 with the TBX-1303. The TBX-1303 is designed for thermocouple measurements and can be used with the SCXI-1102B/C, SCXI-1100, or SCXI-1181. You can use the SCXI-1141 with the SCXI-1304 or SCXI-1305. Here is a great document about terminal blocks to help you with your future decisions.
SCXI Terminal Blocks: http://www.ni.com/pdf/products/us/4scxisc326_ETC_332.pdf
Anna L
(5,372 Views)
