Signal Conditioning
Can I install SCXI-1200 and other NI-DAQ devices on the same computer?
I have the following three devices connected to my computer right now: PCI-MIO-16E-1, AT-MIO-16E-2, SCXI-1200(connected to SCXI-1001 chasis).
For some reason, the 2 E-Series devices (PCI-MIO-16E-1 and AT-MIO-16-E-2) function properly, while the SCXI-1200 always times out when I try to test it. (a base address error is returned). I tried all the trouble shooting procedures listed in this website but didn't succeed.
Is there a compatibility problem between the devices?
(3,483 Views)
Hello;
The main question is; did you try the scxi-1200 by itself on the machine (without having the other devices hooked up to the machine)?
It's important to narrow down the problem to a multidevice compatibility problem or a SCXI-1200 problem.
Regards
Filipe A.
(3,483 Views)
I am having all kinds of problems with confguring my system using the SCXI-1200 module installed in a SCXI-1000 chassis and connected to LPT1 port on my laptop. I noticed that the SCXI-1200 can no longer be found in NI paper, or on-line catalogue. Is there someting that NI know about this product that caused its discontinuation ?
(3,483 Views)
