Signal Conditioning
Can I messure a Straingage signal with PCI-4351 and TBX-68T?
I have a PCI-4351 connected with TBX-68T and some thermocouples, but i want to mesure a loadcell (straingage) signal with this devices.
Is it possible?
Thanks.
(5,015 Views)
Hi Rafael,
You can measure strain gauges using PCI - 4351 but your TBX-68T terminal block for thermocouples dont´support that. Look at PCI-435x User Manual (Chapter 2) and you could see that.
Links:
https://www.ni.com/docs/en-US/bundle/370841b/resource/370841b.pdf
https://www.ni.com/docs/en-US/bundle/321613d/resource/321613d.pdf
Filipe Silva
Application Engineering
NI Brazil
(5,007 Views)
Hi, Filipe
And what devices I have to connect to PCI - 4351 to mesure the strain gauge?
Sorry but I don`t understand eletronics very well...
Rafael.
(5,009 Views)
Hi Rafael, You can´t use PCI-4351 to measure strain gauge you should use other devices. Call sales and they will tell you what devices you could use. Regards, Filipe Silva Appllication Engineering NI Brazil
(4,985 Views)
