Signal Conditioning
Can I use EEPROM memory in SC 2350 in order to write TEDS information?
I want to write TEDS in a DS2431 EEPROM memory using SC2350.
How can I do this?
I've connected the eeprom to TEDS Screw Terminal and I'm using the TEDS EXAMPLE PROGRAMS (http://digital.ni.com/public.nsf/websearch/F09B866779C7C1E786256E38005AAD62?OpenDocument) but it doesn't work. This is the error message:
Error -200791 occurred at DAQmx Write TEDS Data (U8 Array).vi:1
Possible reason(s):
TEDS cannot be configured for the specified channel.
Ensure that your TEDS sensor is connected to the channel through a TEDS interface (for example BNC-2096, SC-2350, or SCXI-1314T), and that this interface is configured in MAX. Alternatively a virtual TEDS file can be used.
I've configured SC-2350 in MAX but MAX doesn't detect the TEDS (I supposed that if there was nothing in the EEPROM, MAX couldn't detect it)
I don't know if I am doing something wrong.
What can I do for writting teds in DS2431?
Thanks.
Message 1 of 1
(5,745 Views)
