Signal Conditioning
Can SCC-RTD01 be used with Cernox RTD's, silicon diode temperature sensors?
   Can the SCC-RTD01 be used with negative temperature coefficient RTD's such as the Cernox RTD's.  Can it be used with silicon diode temperature sensors?
   I was planning on using the SCC-RTD01 with platinum resistance wires, but want a screw mount type sensor.  Couldn't find any platinum RTD devices with screw mounts, but could find the Cernox and diode temperature sensors with the screw mounts.
Mark
(3,518 Views)
Mark,
Thank you for contacting National Instruments!  When you configure an RTD channel in the Measurement and Automation Explorer (MAX), you have the option of choosing from a list of "standard" RTD's or entering your own polynomial expression as the temperature coefficients.  Therefore, negative coefficients shouldn't pose a problem.  Also, I don't see any reason why a silicon diode temperature sensor would pose a problem either.
I hope this information is helpful to you!
Jeff P.
National Instruments Applications Engineer
(3,510 Views)
