Signal Conditioning
Changing Cal Constants does not effect Thermocouple readings
I change the calibration constants using Cal Constant .vi by inputting cal constant 1&2, and write the values to the NI-DAQ memory. And then I sample the corrected channel with a virtual channel, but the values do not change. I verify that the values are correct in the memory by retrieving the values via OpCode 0 and the values are correct in memory. An addition oddity is that when I copy the NI-DAQ memory to the Default Load area the value don�t copy over correctly. Any help you could give would be appreciated! I have a SCXI-1102 running LABVIEW 6.1.
Message 1 of 1
(3,254 Views)
