Signal Conditioning
Clipping with WCDMA/HSPA+ Generation soft Front Pannel
Trying to find resources to correctly set a 50% Clip to a DL Test Model 1 64 DPCH and I can't find any resources for setting that. Using this software.
(3,055 Views)
Hi there,
If the problem still exist, I'll suggest you to  go to RFmx  WCDMA help and explore  Crest Factor Reduction section.
I think you will find lot of useful information regarding to your question.
Meri
(2,576 Views)
I will look into RFmx, but just to clarify for the post. RFmx is compatible with the WCDMA/HSPA+ Generation soft Front Pannel, Or is it a completely different software to generate signals?
(2,565 Views)
