Signal Conditioning
Compact Daq noisy signals on laptop until I plug into external monitor
I have a cDaq 9172 which is mostly populated with AI and universal modules. When used with a DELL laptop through USB this device has always been very noisy, but just the other day I had to plug the laptop into an external monitor and low and behold the noise cleaned up considerably. I then realized the cDaq, power supply is 3-prong earth grounded, and so was the monitor. The laptop's power 'brick' however is 2-pronged and floating ground. It made sense the signal cleaned up once the VGA cable touched the laptop but the issue still exists; I wont always be using an external monitor. So how do you eliminate this ground loop issue?
BTW, I found this white paper on laptop noise and grounding but I've always referenced the signal to AIGND. This is how I got the signal to be tolerably "less" noisy. When reference grounded through the monitor the signal cleans up again twofold.
SCXI- 1000 Chassis w/ 1346 adapter
PCI 6281 DAQ card
SCXI- 1520 Bridge Board w/ 1314 Terminal Block (x2)
SCXI- 1180 Feedthrough Panel w/ 1302 Block
Signal Express 2014.
Win7 Enterprise
(3,824 Views)
Hi, this thread discusses a similar issue. I believe it will be a solution for you too:
http://forums.ni.com/t5/Multifunction-DAQ/Can-we-connect-the-earth-ground-on-a-cDAQ-chassis-to-the-g...
(3,811 Views)
