Signal Conditioning
Connecting a load cell to a SG-24
I need some help in resolving a problem.
I am using a SCC-SG24 in a SC-2350 platform. I have bought a couple of load cells from Transducer Techniques with the TED option (9 pin connector). I can read the TEDs data. Plugging the sensor in drives the signal up to the rail and it won't budge. If I unplug the sensor and 'tickle' the input connector, I see a 'waveform'. This is all through Max.
Looking at the wiring for the sensor, I see the manufacturer has tied the TEDs return to the Sig- and the cable shield to Vex-. Could this be the cause of my problems?
I have verified my wiring and an ohms test of the sensor looks okay. If I supply the 10v excitation voltage I measure 5v across the Signal lines.
Thanks for your help,
David Rogerson
(3,737 Views)
Hello David,
You are correct that the signal is railing specifically because the TEDS return is tied to sig-. This configuration is not compatible with our SCC strain gage modules, because the Excitation- (Vex-) terminal is internal connected to ground, and the TEDS ChnRtn terminals are also internally connect to ground. When your sensor ties the TEDS return to Sig-, it is essentially shorting both AI- and Vex- to ground. This is a problem because your sensor is bridge-based, so both legs of the bridge are intended to be at roughly the same potential of Vex/2 (or 5V) when resting, so when you short one of the legs to ground, then the difference between the two legs suddenly becomes very large (5V), and since there is a gain of 100 on this module, that signal will obviously rail. The way to fix this problem is to remove the path to ground from Sig- by disconnecting it from the TEDS return line. I would recommend contacting Transducer Techniques about this issue so that they can recommend a solution for you (i.e. use wire cutters to disconnect Sig- and TEDS return).
Logan Kunitz
(3,733 Views)
Thank you Logan,
I contacted Transducer Techniques and they confirmed connecting Sig- and TEDs rtn was the problem. They did this for their own products and are changing their manufacturing to prevent this problem in the future. Once I cut the connection, everything was fine.
On another note, are external resistors required for the four LED panellete (185376-01)? I didn't find anything in the datasheets.
Thanks again for your assistance.
(3,726 Views)
Hello drog,
Those LEDs all require ~15mA at 5VDC.
I hope this helps!
E.Lee
Eric
DE For Life!
(3,708 Views)
