Signal Conditioning
Crankshaft position signal processing
Hello All!
I am trying to scope a crankshaft position sensor using MyRio FPGA, I got a nice signal where it shows clearly the missing tooth signal. I am trying to process it to get RPM and Crank angle position, I attached a session of the FPGA run as a delimited text file that can be processed in real time VIs.
Your help is much appreciated!
Hijawi
(3,695 Views)
Accepted by topic author Hijawi
Hello Hijawi,
Have you checked this document?
Decoding Tachometer Signals Using CompactRIO and LabVIEW FPGA
Diego H
(3,643 Views)
Thanks for your reply johndoe214!
I think this will solve my problem I will check and inform you.
(3,634 Views)
