Signal Conditioning
Current and voltage trasformer
Hello to all,
I'm developing a system of power analysis based on "Electrical Power Measurement Toolkit".
I think to use a system based a cRIO-9075 and a NI 9215 (simultaneous sampling).
I think to use this current and voltage trasformers:
The voltage range in output from these sensors (0 - 333.mV) disagrees with that of the acquisition module (0 - 10 V).
There might be a problem of signal levels? In this case, can you tell me how to adapt the signal?
Any other configurations are welcome.
Thank you very much,
Federico.
McTALAO
(5,818 Views)
There is no problem, the NI 9215 has a minimum voltage acurracy of 0.003 V........just set the measuring range of the Daq card in DAQ asistan from 0-10 V ....to 0-1 V.
Have a nice day!
(5,796 Views)
