Signal Conditioning
DMM Probe for Terminal Board
I am performing an application where I need to measure the voltage across two terminals on a terminal board like a CB-50.  It would be great if I can use a set of probes that clip on to the terminal so that I do not have to hold it in place.  Does anyone know of such a probe or suggestions to keep the probes in place?
Thanks!
--Jason
(3,195 Views)
A second set of 'sense' wires under the terminal that connect to the DMM probes via alligator clips? Pomona makes a full line of test leads, clips, etc. Or just drop by a Radio Shack if in the US.
(3,193 Views)
