Signal Conditioning
Data acquisition for pressure sensors
I am using a cDAQ and I have 3 pressure sensors:
- 1 gauge that need an excitation between 11.5 to 26.5 VDC and give an analog voltage output from 0 to 10 VDC
- 2 pressure transducers that need an excitation between 10 to 15 VDC and give an analog voltage output from 0 to 100 mV
I am wondering if there is a single C series module that will do the job? I was thinking about the NI 9237 but it looks like this card is not able to provide the excitation needed for the gauge
(1,542 Views)
Actually, AFAK none of the c-series modules can provide such a high excitation voltage. You need an external power supply to provide the excitation for your sensors and the DAQ modules can read the analog voltages whether it is 0-10V or 0-100mV.
Santhosh
Soliton Technologies
(1,539 Views)
