Signal Conditioning
Data acquisition
Hi there,
I have many sensors to communicate with using labview, and one of which is an audio sensor. for the audio sensor i intend to use the sampling frequency of 44100Hz and for the other sensors a sampling frequncy of 1000Hz. is it poosible to use the same DAQ assistant? if not, how can i go about it.
tjuy
(4,110 Views)
Accepted by topic author tjuy
For different sampling rates, you will need different devices.  Put all of the channels at 1kHz on one DAQ and the channels at 44.1kHz on a second DAQ.  You will then also need two use multiple DAQmx tasks, one per DAQ.  Each task uses a different DAQ Assistant.
(4,087 Views)
Hi everyone!
I was wondering if somebody could help with this one. I have got audio signal from four sensors that I want to save at the of a while loop, I tried using build array vi then to write to spreadsheet vi, but whenever I opened the file I could only see two rows one column of the data. And I expected to see four columns of numerous rows. Please advice on such a problem. Thanks.
(4,017 Views)
