Signal Conditioning
Division by 2000 without 'Quotion & Remainder' bloc (FPGA)
i need to divide a signal by 2000 with LabVIEW FPGA. With this software version it is said that using a 'quotient and remainder' bloc isn't good (it takes a lot of place in the FPGA). I can do division by 2^x with the 'rotate left/right' bloc, but 2000 is not a multiple of 2 🙂
i hope that someone has a solution to my problem ^^
sorry if i made mistakes.
Portmann J.
(5,916 Views)
I'm sorry, i've just found the vi to make a division for LV FPGA
all my apologizes
Portmann J.
(5,913 Views)
How did you implement the division on LV FPGA? Apparently one has to manually set the multiplier and bit shift. Kindly let me know.
Thank you.
(5,012 Views)
You almost never want to divide by a constant on the FPGA, if you're worried about efficiency, as it can be posed as a multiplication by the reciprocal of the constant. The fixed-point data type (FXPDT) makes this easy, but you can also do it with integer types and constant Scale by Power of 2 operations. For example, one integer solution might be to multiply by 2147484 (ie, 2^32/2000), then shift the result by 2^(-32).
FXPDT gives you more control over precision with configurable word lengths and rounding options. A reasonable solution would be to multiply by .000499994 using an unsigned type with word length 16 and integer word length -10 (<+,16,-10>).
(4,993 Views)
