Signal Conditioning
Does a Watlow 96 need a modbus card or is it able to be directly hooked up with a RS232 cable?
Is it possible to wire a Watlow series 96 temperature controller directly to the computer using a RS232 cable?
(3,703 Views)
You will want to check with www.watlow.com on your question. Typically, the modbus protocol is used over RS-232. Therefore, the cable that you would connect to the controller would be an RS-232 cable from the computer. The "language" that the controller and the computer would use to communicate over the RS-232 cable is Modbus. Here is a link to the Watlow site for their information:
Watlow96 Controller
(3,703 Views)
A vi I just finished writing for a Melcor TEC controller uses a Watlow 96. It connects to the RS-232 and uses modbus protocol. Sorry about the late reply.
(3,703 Views)
