Signal Conditioning
Does the SCC-DI01 can be set as a trigger for strain gage measurement?
I used the SCC-SG01 to measure the strain. I need a trigger to activate the gages to get the data when the test happen. Can I use the SCC-DI01 as a trigger for gages for my test? If I can, how I can do it?
(5,652 Views)
Hello hopezx,
The 2345 is a fairly passive device that does not actually have a lot built into it other than the signal conditioning. So the actual thing that we need to look at is the DAQ card that you have attached to the 2345.  What you need to check on is the product page on ni.com to see if your device support digital triggering.  If it does, then you can use a digital trigger for your task just like any other.
Please post back if you have any other questions or would like some more details.  If you do post back, please make sure to let us know what other hardware you are using.
ColeR
Field Engineer
(5,639 Views)
