Signal Conditioning
Error 10810 occurs when running my SCXI prog
Iam running an RT application(PXI-8176 and DAQ Device PXI-6052E) and i have SCXI-1001 chassis and in it a 1520 module,7 1125 modules and one 1102b module.After i had configured when i run an example prog i find iam able to run 1520 and one 1125 module(modules are slot 1 & 2),but when i run other modules it gives an "Unexpected error with number 10810 saying Group Config error"what could be the reason?
(3,177 Views)
Hello Murali,
This is a known issue and i found a CAR(Corrective Action Request) on it. The error seems to occur when you use the 1125 module with 1001 on RT in slots 3 or higher. Also this error seems to be isolated to Traditional DAQ. The work around suggested is using a different module (other than 1125). This may not be a perfect workaround but this is what we have currently. I have included my name in the notify list and will post any solutions the R&D comes up with in future. Hope this helps.
Murali
(3,177 Views)
