Signal Conditioning
Example of NI's Detailed Module/Board Repair Report
Is an example available of NI's Detailed Module/Board Repair Report.  I am returning an SCXI-1581 module for repair under warranty due to a single channel being >25% out of spec.  A detailed repair report can be purchased from NI for $99.  I need to determine if the detailed repair report contains info from which I can determine why the SCXI-1581 module was out of spec after < 6 months usage.
(11,653 Views)
Hi ATI_TechStaff-
     Here is a link to a sample detailed board report:
               Broken link has been removed by the moderator.
     I hope this helps you find what you need!
Gary P.
(11,633 Views)
Gary:
The link you posted cannot be found.
-AK2DM
(11,628 Views)
Gary,
Thanks for the quick response.  I get a Broken Link message when accessing the link directly or by pasting the link address directly into Internet Explorer.  Is there another way I can view it?
(11,625 Views)
Accepted by topic author ATI_TechStaff
Hi ATI -
     I apologize for the broken link.  Here are some pictures of the Detail Repair Report:
Gary P.
(11,596 Views)
