Signal Conditioning
Excel
Bonjour,
j'ai un probleme concernant une écriture dans un fichier excel, mon fichier devenant plein il faut que je puisse enregistrer automatiquement dans un nouveau fichier. Comment faire ?
Good morning,
I have a problem concerning a write to a file excel, my becoming a full roster must be that I can automatically save a new file. How?
(7,003 Views)
Hi Julien89,
do you mean with activex or do you speak about a spreadsheet file? See this thread if you want to use activex
Hope it helps.
Mike
(7,001 Views)
Hi MikeS81,
I speak about a spreadsheet file.
thank you.
(6,997 Views)
Hi Julien89,
ok and where do you have problems with the spreadsheet file? You can use the "Write to Spreadsheet file" function to create a file.
Mike
(6,994 Views)
Check the size of the file before every new save and increment the file name (--> create a new file) if the size is greater than the limit. Feel free to post again if you need further help to implement this solution.
(6,991 Views)
